__ เป็น ดีเจ มือโปร ง่ายๆด้วย มือถือ/ipad + สาย Griffin DJ Cable สำหรับแอพ DJay
สาย Griffin DJ Cable for iphone ipad ipod สำหรับแยกเสียงหูฟังกับลำโพง ในการใช้แอพ djay
The Griffin Technology DJ Cable is designed to be used with iOS mobile devices and enables the Split Output function when using the djay algoriddim app. With Split Output mode enabled, djay sends the master output to the left channel, and the cue output to the right channel. This lets you cue songs through your headphones independently of the mix that's going through the speakers. The cable has connectors for the speaker system, headphones and audio jack for your device.
For iOS mobile devices - enables Split Output when using djay app
Splitter cable allows you to hear the speaker mix and the song being cued up
Connectors for speaker system, headphones and audio jack on your iOS device
Pre-Cueing
Previewing with headphones
The ability to pre-cue, or preview, the next track through your headphones is essential for any DJ to seamlessly mix the currently playing track into the next track. This allows for finding the perfect next track, flawless beatmatching, and creating a mix customized for your crowd.
In djay, there are two ways you can pre-cue your tracks: by using the Split Output function paired with a stereo/mono DJ split cable, or by connecting an external sound card or DJ controller.
A proper DJ split cable lets you cue up the next track in your headphones independently from what the crowd is currently hearing from the speakers, allowing for a smooth mix.
DJ split cables can be enabled through djay’s Split Output function for pre-cueing. Optimal features you want to look for are gold-plated connectors for improved conductivity and better signal, as well as a durable exterior for longevity.
Note: A DJ split cable splits your stereo jack into two mono channels. This means your speaker output using this setup will always be mono (using two duplicate mono output channels).
รายละเอียดสินค้า
อุปกรณ์เสริมสำหรับ ipad, iphone, ipod touch เพื่อใช้เชื่อมกับโปรแกรม DJ สามารถแยกเสียงหูฟังกับลำโพงได้ ของมือ1 เก่าเก็บ
ซื้อมาพันกว่าบาท ขาย 950 ฿
ราคาร้อนเงิน ลดเหลือ 750 รวมส่ง ems/kerry ภายในอาทิตย์นี้
Pre-Cueing
รายละเอียดสินค้า
swukTz.jpg40.7 กิโลไบต์ · จำนวนการดู: 114
swuwUu.jpg66.4 กิโลไบต์ · จำนวนการดู: 98
swu18Z.jpg56.7 กิโลไบต์ · จำนวนการดู: 88
swuZ0I.jpg61.2 กิโลไบต์ · จำนวนการดู: 93
swuccP.jpg68.2 กิโลไบต์ · จำนวนการดู: 91
swug2t.jpg55.2 กิโลไบต์ · จำนวนการดู: 99
swuiye.jpg77.1 กิโลไบต์ · จำนวนการดู: 107
swuxTl.jpg55 กิโลไบต์ · จำนวนการดู: 101
swu7ND.jpg12.4 กิโลไบต์ · จำนวนการดู: 109
swutB0.jpg39.1 กิโลไบต์ · จำนวนการดู: 96
swu9vR.jpg25.7 กิโลไบต์ · จำนวนการดู: 91
swudpy.jpg27 กิโลไบต์ · จำนวนการดู: 86
swuSU9.jpg49 กิโลไบต์ · จำนวนการดู: 90
swuYrJ.jpg69.5 กิโลไบต์ · จำนวนการดู: 94
swu40b.jpg25.3 กิโลไบต์ · จำนวนการดู: 90
swuNcf.jpg34.1 กิโลไบต์ · จำนวนการดู: 93
swuBsa.jpg58.7 กิโลไบต์ · จำนวนการดู: 93
swufyq.jpg24 กิโลไบต์ · จำนวนการดู: 89
swu3j8.jpg57.4 กิโลไบต์ · จำนวนการดู: 91
