What is the best solution to make sure of easy and clear dot alignment? It is not easy to reach with primary manual dot projecting tool, but making better job with a high purity light emitting tool, such as a 635nm red laser diode module. It is projecting highly visible red laser beam from a 635nm red laser diode within 5mW to 100mW.
In process of long lasting dot aligning work, it is being made with good thermal emitting. The adoption of a metal heat sink cooling system and APC, ACC driving circuit board are configured with different size tube diameter of 16mm and 26mm anodized aluminum alloy tube. Every time it is pointing under various working environments, it is preventing harsh occasion of mechanical moving or shocking, this red dot laser is working well with highly stable red dot alignment in multiple occasions. Every time it makes correct use of output power and freely adjusted laser beam focus, it just brings users increasing brightness and accuracy red dot alignment in long lasting use perfectly.
