In a lot of industrial and high tech precise dot measuring work fields, either it is pointing at close or long distance, it is an easy job to make use of a formal brightness beam emitting tool, such as a 650nm red laser diode module. In various industrial and high tech precise dot measuring work fields, after advanced use of qualified glass coated lens and import 650nm red laser diode, it is not only getting highly stable red dot alignment, but also getting highly clear red dot alignment and quite low production cost. According to correct use of output power and easy mounting onto any other industrial machine or device, within the maximum installed distance of 3 meters, this ultra compact size tube made red dot laser enables the most convenient installation, easy reaching and long lasting dot alignment onto various working surfaces effectively.
