Glass Coated Lens 445nm Blue Line Laser Module
When users are getting serious need of highly clear and fine line alignment at quite long work distance, none of manual line aligning tools can be comparable with Berlinlasers 445nm blue line laser module within 50mW to 100mW. Only after easy use of 5V, 9V 1000mA DC power supply, and basic use of thermal emitting system and APC, ACC driving circuit board, it is working well with constant blue laser beam emission at several miles, but also achieving high stability line alignment in long distance.
Being made with qualified glass coated lens within 10 to 110 degree, and strict laser beam stability tests, this blue laser line generator is working well with highly straight and stable line alignment within 0. 5 meter to 6 meters. It gets no effect by moisture or dust as well. When 16mm diameter made blue laser gets proper installation and adjustment of both blue line fineness and line emitting direction, it assures high precision and high speed line alignment for both industrial and high tech precise line measurement works perfectly.
