- 13 มีนาคม 2024
Are you interested in analyzing the method of betting on football scores using mathematics? This is an advanced betting technique, fundamentally applied by betting experts during the match analysis phase. In the following article, we will advise you on understanding this betting technology better, always remembering to choose reputable bookmakers for safe betting.
For example, if you often bet on Asian handicap (Asian handicap odds), you need to know how to calculate the probability of the favorite team winning by how many goals against the underdog team. Or when you bet on Over/Under odds, you also need to know how to forecast how many goals will be scored in the match.
Using the Poisson mathematical method to predict score betting
Football bettors abroad often use the Poisson function in mathematics to study and forecast the match result.
Through the Poisson mathematical function, we can establish virtual models. Inside, it will contain separate common events, operating independently of each other. To calculate the Poisson function, you need to add an additional condition. That is the selected variable must be a positive integer.
Similarly, the possibility of a variable being a negative number or fun88 betting
In football, these variables will represent the number of goals scored in 90 minutes of the match.
Chance events describe periods when goals are scored.
For example: In the match between Everton vs. Leeds Utd. Suppose you see the bookmaker offering Everton with a 1-goal handicap, and the Over/Under odds are 2. We can calculate the probability that Everton can win by a margin of 1 goal, based on the Poisson production function. Then, calculate the total possible score in this match such as 1:0; 2:1; 3:2; 4:3; 5:4.
Regarding betting on Over/Under:
For every goal scored, you need to calculate the probability of the match's score: 1:0; 0:1
If there are 2 goals, then you have to calculate the probability of possible scores: 2:0; 0:2; 1:1.
Similarly, if there are 3 goals, the probabilities will be: 3:0; 0:3; 1:2; 2:1.
And if there are no goals yet, the probability will be 0:0.
Solve the Poisson problem directly in login to fun88
If you're striving to acquire knowledge to solve the Poisson problem now, it will take up quite a lot of your time. Instead, you can search online or find information about the Poisson distribution function algorithm on Wikipedia. Let's explore some reputable betting sites like vaobo to find out more about reliable betting platforms.
Just observing the formula is enough to make you amazed. For those without expertise, how can they handle the Poisson problem quickly?
However, currently, you can utilize Excel to solve the Poisson problem. The implementation phase of the Poisson distribution function is relatively straightforward. After that, you just need to fill in the blank cell of a Report (goals) and the result will be automatically displayed.
For example: suppose the situation is, the home team's gentle goals are 1.6, while the away team's gentle goals are 1.2. If you apply the Poisson function in Excel, you can calculate the probability of goals in the match. Always remember to consult the most accurate football predictions before placing bets.
Is football score betting based on the Poisson mathematical technique really effective?
Football experts will rely on the Poisson function to calculate the probability of how many goals a team can score in a match. But the important condition for this proposition to be executed and yield accurate results is that you must forecast the "correct" average number of goals.
To know how many gentle goals a team scores in a match, you can take almost the goals in a season divided by the number of matches the team participates in. Although this method may not bring absolute accuracy, at least you have some real statistics to verify.
Or you can also compare the playing style of the two teams (their most recent matches or their encounters).
Have you been feeling uncertain about the Poisson technology so far? But that won't bother you anymore. Especially when you participate in football betting at the BK8 bookmaker. You will rely on the odds provided by BK8 and calculate the accurate average Report of the battle within that range.
For example: In the Chelsea vs Brighton match, the BK8 bookmaker offers a goal handicap of 0.5, and the O/U ratio is 2.5. Thus, the average goals of Chelsea will be 1.75, and Brighton will be 0.75.
You can refer to the article: how to deposit fun88
After mastering the use of the Poisson function for football betting calculations, you can completely purchase the probability in familiar types of bets such as O/U, score bets, or handicap bets.
A temporary conclusion about mathematical methods in betting analysis
Through a similar article, we have just finished analyzing the football score betting method through Poisson mathematical technology. This is a solution to help you predict the score with relatively high accuracy. If readers are still unsure how to use probability calculations based on this technique. So, participate in football betting at BK8. Because BK8's football betting website is very standardized, most of the information about the upcoming match is shared. For example, if you have any doubts, just contact us right away.
