Unless the use of any manual dot projecting tool, it makes good job to make use of a Berlinlasers 445nm blue laser diode module for both long lasting and long distance dot measuring works. It is applying an import blue laser diode within 50mW to 100mW. Inside 16mm diameter metal housing tube, it leaves enough space for metal heat sink, and assures highly stable blue dot indication in long lasting use.
This 445nm blue dot laser module is applying qualified glass coated lens and glass window. It also passes through a series of beam stability and aging preventing test, ensuring no light decay or blur. It is operating easy and conveniently as an accessory part. Within freely installed distance of 3 meters, only after correct use of output power, after its easy mounting onto any industrial device or equipment, it assures easy reaching, high brightness and low production cost dot alignment for laser show, laser displaying, military targeting, laser communication and high tech work etc.
