Once line measuring work is processing at a bit longer distance than formal hand reaching, it makes a good job for users to operate an intense beam device of 445nm blue line laser module . The genuine use of an import 445nm blue laser diode gets wide range output power of 50mW to 100mW. Owing to the special use of thermal emitting and APC, ACC driving circuit board, it enables long lasting line projection within 10 hours, and no tube burning out or damage under proper use.
Being made with a qualified glass coated lens within 10 to 110 degree fan angle and strict laser beam stability test up to 24 hours, this laser line generator is achieving highly straight and fine blue reference line within 0.5 meter to 6 meters. It allows the finest line projection within 25 meter and formal lighting occasion. Within freely installed distance of 3 meters, after its proper installation and adjustment to correct position, it provides users the best line aligning solution for all machinery processing work fields effectively.
Applications: laser show, laser displaying, laser medical therapy, laser communication, military targeting and high-tech
