How does DC power 532nm green laser line generator work continuously?
In process of high precision line alignment at different work distances, not easy to reach with prior line drawing work, it makes a better job with a Berlinlasers 532nm green laser line generator within 5mW to 100mW. The advanced use of a metal heat sink cooling system and APC, ACC driving circuit board are configured with different dimension and durable metal housing tube. It achieves excellent laser light cycling use, and highly reliable green laser beam and green line indication within long lasting work time of 10 hours.
Under operation of clear and fine line indication at various work distances, this laser line generator applies a qualified glass coated lens within wide fan angles of 10 to 110 degree. It is projecting highly straight and fine green line lengths within 0.5 meter to 6 meters. It also enables freely adjusted laser line fineness and line emitting direction. Within the maximum work distance of 25 meters, unless the use of sunlight, it provides users excellent line positioning result for all machinery processing works effectively.
Applications: laser cutting for stone, wood, metal, garment, lumber machine, laser car wheel alignment, military targeting and high-tech
