How to get good direction use of 532nm green laser diode module?
7 สิงหาคม 2022
โพสต์
31
  • กระทู้ เจ้าของ
Whenever users are looking for a high precision dot alignment at different work distances, it is might much longer than formal hand reaching, it makes a good job with a Berlinlasers 532nm green laser diode module. It emits the most visible green laser beam from a middle wavelength 532nm green DPSS system. Once it gets basic use of thermal emitting system inside different dimension tube, it achieves good laser beam stability and highly reliable green dot alignment in long lasting use.
Designed with a 5V, 9V 1000mA DC power supply, not limited by long distance or high height, this laser diode module brings users long lasting and no decay light green laser beam and green dot projection from laser beam aperture. It allows long lasting green dot projection within 10 hours, without any effect by overheating and over current impact as well. According to correct use of output power and proper adjustment of laser beam focus, it gets the best quality green laser light source emission and the clearest dot alignment in multiple work fields effectively.
Applications: industrial precise dot alignment, drilling system, laser marking, laser engraving, lab experiment and high tech
