How to make continuous alignment with 445nm blue crosshair laser module?
In any type of highly precise and clear cross line alignment at a quite long work distance, it should be a good solution to operate a highly intense beam emitting tool of a 445nm blue crosshair laser module . Employed by an import 445nm blue laser diode and thermal emitting system inside ultra compact and durable metal housing tube, it just enables easy carrying, long lasting and no decay light blue cross line projection in constant use.
Under operation with a qualified glass coated lens with different fan angles of 10, 15 and 110 degree, this cross line laser module projects different dimension and highly precise cross line alignment in distance. Within wide range output power of 50mW to 100mW, unless it is pointing under sunlight, it is providing users excellent blue cross line generation within the longest extending distance of 25 meters and formal lighting occasions etc.
Applications: industrial precise cross line alignment, laser medical therapy, laser show, laser displaying, military targeting and high tech
