Not the same as any prior line drawing or printing work, without any limitation by long distance or high height, it always makes good job with a highly bright beam 532nm green line laser module . The basic use of thermal emitting system is configured with durable 16mm and 26mm diameter metal housing tube. Within freely installed distance of 3 meters, it enables easy carrying, good thermal emitting and highly reliable green line alignment in continuous use.
Only after easy connects with 5V, 9V 1000mA DC power supply, this separate crystal lens made laser line generator begins to work with constant green laser light source emission and highly uniform green line projection. It gets various line lengths of 0.5 meter to 6 meters. When it gets wide range output power of 5mW to 100mW, within long extending distance of 25 meters, it brings users no barrier, no manual labor force import and long lasting line projection for all precise line measuring works.
Applications: lumber machine, saw mill, laser car wheel alignment system, military targeting, laser medical therapy and scientific experiment etc
