https://www.berlinlasers.com/445nm-blue-laser-diode-module
Under operation of highly precise dot indication at quite long work distance, not easy to reach with manual dot projecting work, it makes better job for users to operate an intense beam 445nm blue laser diode module. Being made with an import blue laser diode and cooling system, after special use of 16mm diameter tube, it enables easy carrying, good thermal emitting and highly reliable blue dot projection in constant use.
The qualified glass coated lens and glass window are configured into durable metal housing tube, this 445nm blue laser diode module enables high intensity blue laser light emission and highly clear blue dot projection at long distance. It allows long lasting dot indication within 10 hours, without light decay or dim in proper use. Within freely installed distance of 3 meters, it makes no barrier, no mistake and low cost dot alignment in all occasions effectively.
Applications: industrial precise dot alignment, laser show, laser displaying, laser communication, optical instrument and high tech
