https://www.berlinlasers.com/515nm-5mw-50mw-green-laser-line-generator
How does glass lens 515nm green laser line generator work perfectly?
Until the time users are trying to make highly precise and clear line alignment at different work distances, it should be the most efficient job for users to use a direct diode emission made 515nm green laser line generator. It emits intense and highly visible forest green laser beam directly from a 515nm green laser diode. Only after its basic use of good thermal emitting inside different dimension tube, it enables easy installation, good beam stability and highly clear green line alignment in constant use.
This 515nm green laser module applies durable anodized aluminum alloy housing tube, within freely installed distance of 3 meters, it is working well within wide range operating temperature and other harsh occasion etc. According to correct use of output power and optic lens fan angle, within long extending distance of 25 meters, it makes sure of high precision and high fineness green line indication for all machinery processing works perfectly.
Applications: lumber machine, laser car wheel alignment, military targeting, laser medical therapy and high tech work etc.
