How does gaussian beam 532nm green line laser module work at different distance?
When high precision line alignment is processing at various work distances, not the same as manual line drawing work, it makes better job with Berlinlasers 532nm green line laser module within 5mW to 100mW. Employed by advanced 532nm green DPSS laser tech and qualified glass coated lens within 10 to 110 degree, it projects high brightness green laser light, and highly fine green line alignment in constant use.
This laser line generator projects highly straight and fine green reference line within 0.5 meter to 6 meters. After quite easy screw of adjustable focus optic lens, it allows freely adjusted laser line fineness and highly concentrated green laser light emission in distance. Only after its proper mounting onto industrial device, it brings users no barrier and no mistake line alignment for all occasions constantly.
Applications: lumber machine, laser cutting, saw mill, lumber machine, laser car wheel alignment and high tech etc
