https://www.berlinlasers.com/532nm-green-line-laser-module
How does wide angle glass coated lens 532nm green line laser module work continuously?
In order to make sure of highly precise and highly fine red line alignment work at different work, no matter it is pointing at close long distance, it always makes the best job to operate a high brightness device of 532nm green line laser module. Owing to its low laser beam divergence and special TEM00 laser beam mode, it always enables the finest and the brightest green line indication among all visible lasers.
Available with qualified glass coated lens within 10 to 110 degree, cooperating with a glass window inside durable metal housing tube, this laser line generator has just got perfect protection of itself, without any effect by moisture or dust as well. When it projects highly straight green line within 0.5m to 6 meters, within wide angles of 10 to 110 degree, it enables the finest and the most precise green line indication within the maximum work distance of 25 meters and highlighting working etc.
Applications: laser cutting machine, saw mill, laser car wheel alignment, military targeting and high Tech work, etc.
