Quick Response 635nm Red Laser Diode Module
When you are looking for a highly precise dot measurement at different work distances, a high brightness device of 635nm red laser diode module just assures high purity and high intensity red laser light emission from laser beam aperture. After correct use of 5V, 9V 1000mA DC power supply, it enables quick response and highly clear red dot projection onto a lot of working surfaces.
This 635nm red dot laser applies qualified glass coated lens and glass window inside metal housing tube. It enables highly clear and accurate red dot projection, and no effect by moisture or dust as well. According to correct use of output power and easy installation onto industrial device, it assures high precision and long lasting dot alignment for drilling system, laser marking, laser engraving, military targeting and lab experiment work etc.
