https://www.berlinlasers.com/650nm-red-line-laser-module
What is the best solution of a DC power 650nm red line laser module?
Not relying on any manual labor force input, either line aligning work is processing at close or long distance, it always makes good job with a DC power 650nm red line laser module within 5mW to 100mW. The usual use of an import 650nm red laser diode and cooling system is configured with different dimension metal housing tube. It enables easy carrying, highly stable and reliable red line alignment in proper use.
Owing to easy connects with 5V, 9V 1000mA DC power supply, this glass coated lens made laser line generator begins to make constant red laser beam and red line projection. It enables long lasting line projection within 25 meters and formal lighting occasion etc. Within wide fan angles of 10 to 110 degree, after projection of highly fine and straight red line within 0.5 meter to 6 meters, it provides users perfect line aligning solution for both of industrial and high tech work fields constantly.
Applications: industrial precise line alignment, laser cutting, saw mill, laser car wheel alignment, laser medical therapy and high-tech
