- 27 ก.ย. 2023
Are you a newcomer to the world of football betting, struggling with calculating your wagers? Fear not, the following article will equip you with all the knowledge needed to understand the most accurate methods for calculating money in football toolbetting.com betting.
Why Players Need to Know How to Calculate Money in Online Football Betting?
Many newcomers often rely on the automatic features of bookmakers, leading to the risk of losing money unfairly due to a lack of understanding of the calculation methods. Mastering these skills brings immense benefits:
Understanding the figures related to odds and bonuses helps you make appropriate betting decisions based on financial capability and increases the chances of winning.
Bookmakers only calculate money when the match ends, not based on hypothetical situations. Understanding the calculation method helps you confidently predict outcomes and avoid falling into bookmakers' traps.
Comparing calculated results with the automatic features of bookmakers is an effective way to evaluate the reliability and accuracy of the chosen bookmaker.
Guidelines for Easily Understanding How to Calculate Football Betting Money
Below are formulas for calculating money in football betting according to different types of bets with specific scenarios.
[H2]Calculating Asian Handicap Betting Money[/H2]
Asian Handicap, or 1×2 betting, is one of the most popular types of odds with simple and understandable rules. Players only need to predict the overall outcome of the match, including three betting options:
Win (1): Betting on the home team to win. Draw (X): Predicting the match to end in a draw. Loss (2): Betting on the away team to win. The advantage of Asian Handicap betting is suitable for beginners. When placing a bet, you wager the entire bet on a single option. If your prediction is correct, you will receive winnings based on the chosen odds.
The formula for calculating money in Asian Handicap betting is as follows:
Winning bet: Payout = Bet amount x Chosen odds Losing bet: Lose entire bet amount Although Asian Handicap betting is straightforward, it requires players to have knowledge and careful analysis of the participating teams to make accurate predictions. Therefore, football score advises newcomers to consider carefully before placing bets and manage their betting capital wisely.
Note:
The odds for each betting option will vary depending on the bookmaker and the strength of the teams. It's advisable to consult multiple sources of information and analyze carefully before placing bets.
[H2]Calculating Betting Money in Asian Handicap[/H2]
Asian Handicap, also known as Handicap betting, is one of the most popular types of football betting. This type of bet attracts players due to its attractiveness and potential for high profits. However, to participate in Asian Handicap betting effectively, you need to understand the formula for calculating money in football betting as follows:
General formula: Payout = Bet amount * Odds ratio. Full win: Winning amount = Original bet * Win odds ratio. Half win: Winning amount = (Bet ratio * Bet amount) / 2. Full loss: Loss amount = Bet amount. Half loss: Loss amount = (Bet amount * Odds ratio) / 2. Calculating Betting Money in Over/Under Betting
Over/Under betting, also known as Total Goals betting, is one of the most popular types of betting odds offered by bookmakers. This type of bet attracts players because of its simple rules, easy understanding, and high chances of winning.
The special feature of this betting type is that it does not focus on the result of the match but only on the total number of goals scored in the match. Therefore, the formula for calculating money in football betting Over/Under is as follows:
Full win:
Over bet: If the total number of goals scored is higher than the Over/Under odds ratio, players who bet on Over will win their entire bet amount. Under bet: If the total number of goals scored is lower than the Over/Under odds ratio, players who bet on Under will win their entire bet amount. Full loss:
Over bet: If the total number of goals scored is lower than the Over/Under odds ratio, players who bet on Over will lose their entire bet amount. Under bet: If the total number of goals scored is higher than the Over/Under odds ratio, players who bet on Under will lose their entire bet amount. Half win:
Over bet: If the total number of goals scored is equal to the Over/Under odds ratio, players who bet on Over will only receive a refund of their bet amount. Under bet: If the total number of goals scored is equal to the Over/Under odds ratio, players who bet on Under will only receive a refund of their bet amount. Half loss:
Over bet: If the total number of goals scored is higher than the Over/Under odds ratio by 0.25 (e.g., 2.25), players who bet on Over will lose half of their bet amount. Under bet: If the total number of goals scored is lower than the Over/Under odds ratio by 0.25 (e.g., 2.25), players who bet on Under will lose half of their bet amount. Important Notes When Calculating Money in Online Football Betting
The odds table for football betting helps players understand how to calculate bonuses for each type of bet. For each match, bookmakers will offer different odds ratios, reflecting the correlation of power and the winning probability of the two teams. Depending on the type of bet, such as Asian Handicap, Handicap, or Over/Under, the method of calculating betting money will have specific differences. Despite differences in bet types, the general formula for calculating betting money at bookmakers is relatively similar. Mastering this formula allows you to easily calculate the amount won or lost after each match. Choosing a reputable bookmaker is a key factor in ensuring transparency and accuracy in calculating betting money. Reputable bookmaker toolbetting will provide calculation support tools to help you easily track and manage your betting account. Conclusion
With the information above, it can be seen that calculating money in football betting is not too difficult. The important thing is that players must know how to assess and make accurate predictions for the type of bet they want to place. Finally, don't forget to visit our website to explore many other exciting betting options.
Note:
Full win:
