What is an easy job to make highly precise cross line alignment in distance? No matter it is pointing at close or long distance, and high lighting occasions, it is always making good job with a high brightness Berlinlasers green cross line laser module. It projects the most visible and the brightest green laser light from a 532nm green DPSS laser system. Within wide range output power of 5mW to 100mW, it enables high precision cross line alignment within long lasting distance of 25 meters and high lighting etc.
Available with 16mm and 26mm diameter metal housing tube, and extending electric wires, this green cross laser alignment enables freely installed distance of 3 meters, and keeps work with highly stable cross line projection under mechanical moving or shocking etc. After its proper installation and adjustment of laser beam focus, it assures no mistake measurement for military targeting, laser medical therapy, heat transfer machine and laser alignment for screen printing system etc.
