In various industrial precise dot measuring work fields, not easy to reach with a simple blue laser pointer, it just makes a better job to operate a DC power supply made 445nm blue laser diode module . Being made with an import 445nm blue laser diode and cooling system inside 16mm diameter metal housing tube design, it always enables easy carrying, good thermal emitting and increasing stability blue dot alignment within long lasting work time of 10 hours.
Owing to the most charming and attractive blue laser light emission from a blue laser diode, this direct diode emission made blue laser diode module is not only used for industrial precise dot measurement, but also making good job for special fields. It gets different output power of 50mW to 100mW. Usually within the maximum work distance of 25 meters and other formal lighting occasions, after correct use of output power, it provides users excellent dot aligning solution for all application fields effectively.
Applications: industrial precise dot measurement, laser show, laser displaying, laser communication, optic instrument, military targeting and high tech
