What is a 1.5 Goal Handicap? How Does Betting on 1.5 Goals Win or Lose?
  • ผู้เริ่มหัวข้อ ผู้เริ่มหัวข้อ nhuy5656
nhuy5656
12 ม.ค. 2024
What is 1.5 Goal Handicap? If you're just stepping into the world of online betting, you definitely need to understand this concept. This basic knowledge from Wintips will help you establish a solid foundation to achieve your desired prize goals.
-gXhx-phdwaaOqFqoypUYM8q9j3KtVoC3oo_WhC0rIupCfk4lDIzd7Q2gzTiN3k7VPNxqiGQ0DHNOm0guWxrTGmegP47_9qr6dQrP_uaJ1foKKFzFWx5AoL1fBbLYwrA6p9sV_jt7AcbOJMvBsWdXtY
[H1]What is a 1.5 Goal Handicap? Basic information to answer your questions[/H1]
In the betting system, there is no shortage of matches where tip win sets the 1.5 odds, but what exactly is this form of betting? This question is easily understandable when players can see two types of odds appearing with a ratio of 1.5:
The 1.5 odds represent the Asian Handicap 1 ½, which bookmakers offer in matches where there is a significant difference between the two teams. In this scenario, the stronger team (the favorite) will have to give a handicap of 1.5 goals to the weaker team (the underdog).
Over/Under (O/U) also appears with odds of 1.5. With this type of bet, Wintips will analyze information and provide a figure to predict the total number of goals and other match statistics.
Players will win if they correctly predict Over or Under, meaning they correctly determine whether the actual statistics are higher or lower than 1.5.
[H1]How do bettors win or lose on a 1.5 goal handicap bet?[/H1]
You must have understood the 1.5 odds by now, which could be either the Asian Handicap or the Over/Under bet appearing on the Wintips betting system. Therefore, if you want to know how you win or lose when placing bets, you need to analyze both types of odds:
[H1]What are the scenarios for winning or losing on a 1.5 goal handicap?[/H1]
Understanding all the winning and losing scenarios is the key for bettors to seize the opportunity to win prizes at Wintips. Therefore, let's delve into specific scenarios in both types of 1.5 odds:
For the 1.5 handicap bet, depending on the actual situation of the match, bettors can win or lose as follows:
Choosing the winning handicap team: If, after the official playing time, the handicap team wins by a margin of two goals.
Choosing the losing handicap team: If the winning team still belongs to the favorite team, but the goal difference is only one goal, or if both teams draw or unexpectedly the underdog wins by three points.
When the 1.5 odds represent the Over/Under bet, two scenarios can occur:
Placing trust in the Over bet: If you bet on Over, you win if there are two goals scored in the actual match.
Predicting a loss for the Over bet: If you bet on Under, you win if neither team scores any goals or only one goal is scored.
[H1]Exact calculation of wins and losses using the precise formula[/H1]
Understanding the 1.5 odds and the potential outcomes of winning or losing, it's important to grasp the calculation formula to know your position:
Winning amount = Initial stake x Positive win odds (use 1.0 to calculate winnings if the odds on the betting board are negative).
Losing amount = Initial stake x Negative loss odds (use 1.0 to calculate losses if the odds on the betting board are positive).
[H1]Detailed guide on reading the 1.5 goal handicap odds[/H1]
Once you've firmly grasped the winning and losing scenarios, it's essential to come to a reputable platform and select a specific betting board to practice. However, before diving in, let's first understand the basic method of reading odds to avoid confusion when placing bets:
[H1]1.5 goal handicap on bookmakers' betting systems[/H1]
What is a 1.5 Goal Handicap? By reading the 1.5 Goal Handicap odds, you'll understand it right away. Here are some key points for bettors to pay attention to:
Bet Name: Handicap/ HDF.
Time: Full match/ Half-time.
The actual match time is listed on the left side of the team name column.
Team Name: The home team is listed above, and the away team is listed below. The handicap ratio is listed alongside the team name, indicating which team is the favorite.
Handicap Ratio: 1.5.
The ratio used to calculate the winnings for the team will be listed alongside its name.
[H1]Basic understanding of the Over/Under 1.5 goal odds on the betting board[/H1]
If you're planning to make money with the Over/Under 1.5 goal bet, then here's how to read the basic odds:
Bet Name: Over/Under or Over/Under 1.5.
Time and match information are similar to those in the 1.5 Goal Handicap odds.
Team Name: The team listed above is the home team, while the team listed below is the away team.
Bookmaker's full time home win prediction: 1.5.
Winnings Ratio: The numbers listed alongside the Over/Under options.
[H1]Practical application using the 1.5 goal handicap on real-life betting boards[/H1]
Do you understand what a 1.5 Goal Handicap is? Have you grasped all the basic knowledge yet? Let's practice together with the following example, and you will quickly become proficient in both types of odds:
[H1]Real-life scenarios with the 1.5 goal handicap[/H1]
Example of a betting board for the match between Besiktas vs Konyaspor on the online gaming system to understand the 1.5 odds:
Bet Name: Full Match Handicap.
Actual match time: 12:00 AM, June 8th, 2023.
Team Names: Besiktas is the home team considered the favorite by the bookmaker, Konyaspor is the away team considered the underdog.
Winnings Ratio: Correctly predicting Besiktas to win earns a reward with odds of 0.89, while Konyaspor has odds of 0.97.
At the end of the match, the following scenarios will occur after placing a bet of 100,000 VND for the home team:
Choosing Besiktas to win earns 100,000 x 0.89 = 89,000 VND if the match ends with the home team winning by a margin of 2 goals.
Choosing Besiktas to lose results in a loss of 100,000 VND if the match ends with the home team winning by a margin of 1 goal, drawing, or losing.
[H1]Practical examples with the Over/Under 1.5 goal odds[/H1]
With the Over/Under 1.5 odds, players can explore the betting board for the match between Ankaragucu vs Adana Demirspor with Wintips.
Bet Name: Over/Under Full Match.
Match Information: 12:00 AM, June 8th.
Team Names: Ankaragucu is the home team, and Adana Demirspor is the away team.
Bookmaker's best soccer prediction app: 1.5.
Winnings Ratio: Betting on Over earns a reward of 0.91, while Under has odds of 0.79.
[H1]Tips for ensuring success when betting on the 1.5 goal handicap[/H1]
When betting with Over/Under or 1.5 Handicap odds, players also need to gather additional information if they want to increase their chances of winning. Here are some experiences you should consider applying:
Firstly, you need to eliminate emotional impulses when placing bets by thoroughly analyzing the match before making a decision. This should be done even if the match with 1.5 odds involves two teams with a significant difference in form.
If you choose to bet on the Over/Under 1.5 odds, make sure to check the head-to-head history for accurate betting groundwork. This type of bet is often offered for the first half, so players should examine the historical data for this period.
If the home team has a strong attacking lineup, consider betting on them and on the Over option for the Over/Under 1.5 odds.
Understanding what 1.5 odds entail shouldn't be difficult with the information provided here. If you have mastered the knowledge, then head straight to a reputable platform and apply it. Don't hesitate to sign up with the best telegram tipsters for an experience, and don't miss out on the exciting sports betting information available here.
    725.7 กิโลไบต์ · จำนวนการดู: 46
    725.7 กิโลไบต์ · จำนวนการดู: 44
