For those who have been involved in football betting for a long time, the concept of "kèo thơm" is likely familiar. It is a key to unlocking winning bets and earning money from football betting. So what exactly is "kèo thơm"? And what is the most effective way to analyze it in 2023?
Boost your betting success with our free soccer tips
What is "kèo thơm"?
The term "kèo thơm" appears frequently in football betting, but not everyone understands it clearly. Some confuse "kèo thơm" with draw bets, handicap bets, or over/under bets. However, in reality, it is not the same.
Simply put, "kèo thơm" refers to a type of football bet with a high winning probability, as indicated by the odds offered by the bookmaker. If a player correctly identifies a "kèo thơm" and places a bet on it, they can easily win the full reward. Therefore, this type of bet is capable of recovering the initial capital and generating additional profits.
Usually, "kèo thơm" does not appear clearly at the beginning of the odds table. To identify which bets have a high winning probability, players need to focus on observing and analyzing the two teams and the match situation. In some cases, the match dynamics may change, causing the "kèo thơm" to change as well. Players need to master the accurate way of recognizing such bets to avoid missing out on them!
The most effective method for analyzing "kèo thơm" in 2023
In every football betting match, experienced bettors prioritize finding "kèo thơm" in the initial odds table. This type of bet offers a high winning rate and allows players to easily earn significant rewards. Therefore, taking a few minutes to understand these bets will increase the chances of winning.
Analyze "kèo thơm" based on the odds
This is currently the simplest method for analyzing "kèo thơm." In the case of a match between the top-ranked team and the bottom-ranked team, the top-ranked team may have a handicap of 1 goal, but the odds decrease to 3/4 goal just before the match starts. At the same time, the payout odds also increase. This type of bet can be easily identified through the score. You should seize this opportunity and place your bet on the underdog team to increase the chances of winning.
If the Asian handicap odds lean more towards a draw, with the Asian handicap increasing to 1/4 goal, then players should bet on the home team. The home team has the advantage of playing on their home ground, better physical condition, and smart gameplay, which can lead to victory. If a team has a good away performance and a handicap of 1/2 goal, players should not risk choosing the team in good form. This is because teams often perform well when playing at home.
Winning bets is not difficult with telegram betting tips
When playing away, factors such as weather conditions, physical fitness, and endurance will affect the performance of the team members. In such cases, it is safer to place your bet on the home team. The home advantage will boost morale and provide extra strength for the team to play more passionately. If the bookmaker offers odds between 0 and 0.25, players should bet on the away team. Compared to odds of 0.25, this betting option has a much higher chance of winning.
In addition, players can identify "kèo thơm" through the fluctuation of odds. About 30 minutes before the match starts, the bookmaker will continuously adjust the odds, causing early bettors to feel uncertain and worried. That's why you shouldn't place your bets too early; instead, wait and observe the odds movement. If the odds decrease from 1/4 to 0 but the payout increases for the 1/4 odds, it is safest to bet on the underdog.
Analyzing "kèo thơm" in major tournaments or based on teams
If you are a beginner and not skilled at analyzing match situations, major tournaments are the best choice. Major tournaments often attract significant attention from the media, experts, and detailed analysis. Therefore, all you need to do is gather and search for information, then summarize to make an accurate conclusion.
When playing in major tournaments, you can easily predict sure-winning "kèo thơm" without much analysis effort. Furthermore, major tournaments experience fewer match-fixing incidents, are strictly monitored, and played in a serious manner.
Analyzing "kèo thơm" based on Asian handicap and European odds
Players need to monitor the Asian handicap odds about 30 to 60 minutes before the match starts. This is the golden time but also requires the utmost caution. In the case of a significant decrease in Asian handicap and European odds, the home team will have a higher chance of winning.
Find out more information : soccer tips website
However, players should also note that if the odds gradually increase, it could be a trap set by the bookmaker to attract more participants. You need to regularly follow the betting system to make the most accurate betting decisions.
Capturing "kèo thơm" is not an easy task, especially for those who are new to this field. Therefore, to increase the chances of winning, you should continuously update your football knowledge and choose bets that suit your preferences.
What is "kèo thơm"?
