Unlike the use of any manual dot aligning work, either it is pointing at close or long distance, it should be the best job to operate a Berlinlasers 445nm blue laser diode module. The unique use of metal heat sink cooling system and APC, ACC driving circuit board are cooperating well, once it makes constant blue dot alignment within 10 hours, it gets high level of laser light cycling use and highly reliable blue dot projection in long lasting use.
On the basis of special use of electric wires extension for both of laser diode module and DC power supply, within freely installed distance of 3 meters, it makes easy reaching and no barrier dot alignment in continuous use. Usually it should be selected with correct output power, after proper adjustment of laser beam focus optic lens, it gets the best quality blue laser light source emission and high level of accuracy blue dot alignment at great distance.
Applications: laser show, laser displaying, laser medical therapy, optical instrument, spectrum analysis and high tech etc
