- 5 สิงหาคม 2022
- 32
For those deeply involved in football betting, the array of available bets in this game is a constant source of fascination. Among them, throw-in *** consistently draw significant interest from a large segment of bettors. So, let's explore high odds soccer tips to what throw-in *** entail and whether there are any tips to play this *** effectively.
What are throw-in *** bets?
These are popular wagering forms provided by bookmakers in football betting. In this type of ***, the bookmaker consolidates the number of corner kicks that will occur during a match. They analyze each corner kick *** to determine the outcome for the bettors.
Following the basic rules on the football field, if the ball crosses the touchline and touches a player from the opposing team, the team whose player was not responsible for the ball leaving the field will be awarded a throw-in ***. This player will then restart the game.
Generally, corner kick bets are categorized differently depending on each bookmaker. Specifically, these bets are divided into three main types: the first corner kick ***, handicap corner kick, and over/under corner kick.
Understanding the first throw-in *** ***
Now that we have an overview of what corner kick bets involve, let's delve into the first corner kick ***, which is the most straightforward and suitable for beginners. This *** doesn't require extensive experience or betting skills but relies more on chance. Therefore, newcomers often favor this ***.
To play this ***, you predict whether the away or home team will have the first corner kick. It's crucial to note that the corner kick must adhere to the referee's rules and be valid to count as the first throw-in ***.
Compared to the other two types of throw-in *** bets, the first throw-in *** is a starting point for acquainting yourself with this type of wager. Many beginners have won significant amounts and changed their fortunes after just one ***. This illustrates the high payout rates offered by bookmakers and the substantial chances of winning.
Additionally, even if you lose the ***, you won't lose a substantial amount of money. This is because bookmakers currently have a program that refunds up to 1% for this type of ***. Hence, there's no need to worry about losing everything.
Handicap throw-in ***
Also known as the Asian handicap throw-in ***, this is an intriguing type of *** that determines the win or loss based on the number of corner kicks by both teams during the match. So, how is the *** calculated in a Handicap corner kick?
Bookmakers will study and specify which team will give a handicap to the other team with a certain ratio. If the handicapped team has corner kicks exceeding the specified ratio, the bettor who placed the *** on this team will win the ***. Conversely, if the handicapped team has fewer throw-in *** than the specified ratio, you will lose the ***.
In the event the handicapped team has the same number of corner kicks as the specified ratio, it's considered a draw. In this case, all bettors will receive a refund. Additionally, there are instances where handicap ratios result in half-wins or half-losses for the bettors.
View more articles : what is an asian handicap in soccer
What is the trick to betting on throw-in handicaps in football?
In Asian handicap throw-in betting, the number of throw-ins by the teams and the handicap betting odds for each match will determine the win or loss for the bettor. While these are just two basic parameters, players need to equip themselves with a lot of playing experience and other factors to accurately predict this type of ***. Here are some tips for playing throw-in handicaps:
Analyze the playing style and tactics of both teams
The playing style and tactics of both teams will significantly impact the outcome of throw-in bets. For matches featuring evenly matched teams, place your trust in the home team. They will have the advantage in terms of home ground and their psychological state on the field will likely be better than that of the away team.
Teams playing long-ball tactics or frequently engaging in fierce ball disputes, or those inclined towards more attacking rather than defensive play, will have an edge in throw-ins. Therefore, consider placing your bets accordingly.
Especially, similar to other handicap bets, thoroughly analyzing information about both teams such as playing style, tactics, match history, recent throw-in statistics, etc., is a basis upon which you can effectively analyze the odds.
Learn more from credible sources about analyzing bets
One factor contributing to your success in each *** is learning. It's crucial to gather knowledge and experience to excel in throw-in handicap betting. It's even better if you know where to seek reliable references. So, what are the sources to predict throw-in handicap bets?
Typically, players can seek insights from experts, betting analysts, or reputable websites providing betting analysis. However, take these lessons as references, avoid overreliance, to prevent unexpected outcomes. Select and assimilate information sensibly!
Choose the right timing to place throw-in handicap bets
For throw-in handicap bets, you don't need to act impulsively or hastily. Instead, you can choose to *** at any time: during the first half, second half, or the entire match. Thus, monitor the game you wish to *** on in the first half, then make a calculated decision for the second half. This will increase your betting success rate.
Moreover, avoid changing your decision at the last minute. Sometimes, the initial decision brings luck. Changing your *** hastily won't yield high effectiveness.
Carefully observe player substitutions
If this situation arises, observe it attentively. This factor can directly impact the match outcome. If a newly substituted player specializes in playing on the wing, handling play along the sidelines, the number of throw-ins during the match will significantly change, becoming more frequent.
Furthermore, if a player need acess betting tips sites with a tendency to play on the flank enters the lineup, that team will attack more on the wings. Take note of this to consider adjusting your betting decisions accordingly!
Monitor changes in the bookmakers' odds
If there are changes in the betting odds compared to the initial ones, focus on analyzing this factor. Usually, bookmakers adjust the odds based on the match situation. You can rely on this to understand the bookmakers' thoughts and make the most accurate additional bets or changes to your existing bets.
Above is all the information addressing the query 'what are throw-in handicaps?' I hope that with the information provided in this article, you will gain a better understanding of this intriguing betting type. Wishing you happiness and successful moments in your betting endeavors!
