Good Deal of 650nm Red Line Laser Module
In order to make highly clear and fine enough line alignment at various work distances, it is working well with a direct diode emission device, such as Berlinlasers 650nm red line laser module. After easy use of a 5V, 9V 1000mA DC power supply and easy use of a metal heat sink cooling system, it just leaves enough space for tube cooling down, but also assures highly stable and reliable red line alignment in long lasting use.
In process of long lasting line aligning work fields, on basis of easy use of a qualified glass coated lens within 10 to 110 degree, this red laser line generator is working well with high linear quality and highly fine red line within 0. 5 meter to 6 meters. After correct use of optic lens degree and freely adjusted red line fineness, it assures low price and long lasting measurement for sand milling, lumber machine, laser cutting, high tech and lab experiment work etc.
