How to make easy measurement with DC power 635nm red laser diode module?
In a large variety of industrial and high tech precise dot alignment work fields, either it is pointing at close or long distance, it makes a good job to operate a DC power supply supported 650nm red laser diode module. Employed by an import 650nm red laser diode within 5mW to 100mW and basic use of thermal emitting system, it achieves good laser beam stability and highly reliable red dot projection in continuous use.
The unique use of a glass coated lens and glass window are configured with a highly durable metal housing tube. When laser diode module projects high transmittance and low divergence red laser beam emission, it also enables the brightest and the most precise red dot alignment in constant use. According to real work distance and lighting occasion, after correct use of output power and freely adjusted laser beam focus, it gets the best direction and the highest level of accuracy red dot alignment for all precise machinery processing works perfectly.
Applications: drilling system, laser marking, laser engraving, red laser sight, laser medical therapy and lab experiment etc
