How to operate a direct diode 445nm blue laser diode module effectively?
When users are trying to make highly precise dot alignment at much longer distance than formal hand reaching, not simply relying on any manual dot projecting work, it makes better jobs for users to operate an intense beam emitting device of 445nm blue laser diode module . It keeps work with intense and moderate brightness blue laser light emission from a 445nm blue laser diode. Cooperating with good cooling system and APC driving circuit board, it just allowed the easy carrying, good thermal emitting and highly reliable blue dot indication in continuous use.
Being made with ultra compact and highly durable metal housing tube design, within freely installed distance of three meters, this 445nm blue laser diode module enables the most convenient installation and the easiest reaching of blue dot indication in continuous use. It always makes sure of non contact, no mistake and long lasting dot indication within the maximum work distance of 25 meters. Only after its proper installation and adjustment of dot diameter and dot emitting direction, it assures high levels of accuracy and high stability blue dot indication at greater distance effectively.
Applications: laser show, laser making, laser displaying, decoration, laser medical treatment, military targeting and high Tech work etc.
