Glass Coated Lens Green Cross Line Laser Module
No matter cross line measuring work is processing at close or long distance, it is the best job to use a 532nm green cross line laser module within 5mW to 100mW. It projects highly visible and bright green laser light from a middle wavelength of 532nm green DPSS laser system. Within wide range work distance and high lighting occasion, after correct use of output power, it brings users highly precise green cross line alignment in use.
Being made with different dimension metal housing tube, within freely installed distance of 3 meters, this ultra compact size tube made green cross laser enables easy installation and quick reaching of green cross line projection. Glass coated lens with 10, 15 and 110 degree achieves different dimension cross line source. Unless it is pointing under sunlight, it brings users no mistake and no barrier cross line projection for all raw material processing works constantly.
Applications: laser alignment for screen printing system, heat transfer machine, laser car wheel alignment, military targeting and high tech work etc
