In order to make highly clear and accurate dot measurement at various work distances, not the same as a simple green laser pointer, the real use of green laser diode module is always working for quite long time and long distance. Being made with good thermal emitting system and constant power source supply, only after its proper installation, it makes easy reaching and highly precise green dot projection onto any raw material surface.
Available with wide range output power of 5mW to 100mW, configured with different dimension metal housing tube, this green dot laser enables long lasting green laser beam emission, and highly stable dot projection in multiple working occasions. Within freely installed distance of 3 meters, it brings users no mistake and no barrier dot measurement for drilling system, laser marking, laser engraving, military targeting and high tech work etc.
