Long Distance Pointing Berlinlasers 50mW 532nm Green Dot Laser Alignment
In process of long lasting and high precision dot measuring work at different work distances, it should be a good job to operate a high brightness device of a 532nm 50mW green dot laser alignment. It emits ultra clear green dot projection within long extending distance. Unless it is pointing under sunlight, owing to its basic use of thermal emitting system and APC, ACC driving circuit board design, it is working well with good laser beam stability and long lasting green dot projection for all machinery processing works.
When alignment laser applies a qualified glass coated lens and glass window in front of laser beam aperture, after passing through strict laser beam stability test, it achieves ultra high density green laser light source emission and highly clear green dot projection at long distance. It gets no effect by harsh occasion of moisture or dust. Only if users are aware of any powerful green laser radiation and taking active laser safety measure, it still brings users excellent dot alignment solution for all machinery processing works constantly.
Application: industrial machinery processing, drilling system, laser marking, laser engraving, optical instrument, high tech
