In those of high tech and industrial precise line measuring work fields, it makes a high efficiency job to operate a Berlinlasers 635nm red line laser module . It gets low laser beam divergence and special TEM00 laser beam mode. Employed by an import 635nm red laser diode within 5mW to 100mW, it is working well with pure red laser light emission and highly clear red line projection in constant use.
Being made with a qualified glass coated lens within wide fan angles of 10 to 110 degree, cooperating with up to 24 hours aging preventing test, this laser line generator is working well with high linear quality and highly fine red line emission within 0.5 meter to 6 meters. It enables long distance extending red line projection in continuous use. Within freely installed distance of 3 meters, not limited by long distance or high height, a correct output power and optic lens fan angle made laser device brings users high precision and good direction line generation for all precise machinery processing works continuously.
Applications: saw mill, lumber machine, laser cutting, laser car wheel alignment, laser medical therapy and high-tech
