When dot projecting work is processing at a bit longer distance than formal hand reaching, it is just the best time to try 10mW 532nm green laser diode module. It emits the brightest green laser light source from a middle wavelength 532nm green DPSS laser system. Owing to its low beam divergence and special TEM00 laser beam mode, either it is pointing at close or long distance, it always enables ultra compact size green dot projection clearly.
After easy mounting onto desired machine or device, within freely installed distance of 3 meters, this laser diode module makes a no barrier, no mistake dot projection in continuous use. It gets unique use of a glass coated lens and glass window, which enables qualified green laser light emission and ultra clear green dot projection in multiple working occasions. After its proper adjustment of both of green dot diameter and dot emitting direction, it makes the highest level of accuracy green dot alignment for all machinery processing works effectively.
Applications: drilling system, laser marking, laser engraving, military targeting, scientific research and lab experiment
