Either line projecting work is processing at close or long distance, not easy to reach with manual line drawing work, it would be a much better job to operate a Berlinlasers pro red line laser alignment. Employed by an import 635nm red laser diode within 5mW to 100mW and thermal emitting system inside different dimension metal housing tube, it achieves good laser beam stability and long lasting red line projection within long lasting work time of 10 hours.
This red alignment laser applies high quality glass coated lens or separate crystal lens within wide fan angles of 10 to 110 degree. It passes through strict laser beam stability test and aging preventing test up to 24 hours. After getting basic learning of required line length, line fineness and work distance, after correct use of output power and optic lens fan angle, it provides users excellent line positioning results for both of industrial and high tech fields continuously.
Applications: industrial device manufacturing, laser cutting, saw mill, lumber machine, laser car wheel alignment, high tech
